Activity Forums VEGAS Pro Aspect ratio jumps on first few frames
  • Aspect ratio jumps on first few frames
    Posted by Chris Callaghan on March 20, 2008 at 3:40 am
    I have done a Sony Vegas 8 multicam 3 camera project, all cameras supposedly using 16:9. 1 HD cam, and 2 SD cams.
    I noticed the footage from the HD cam was slightly different, and set each segment to “match output aspect” and sometimes used pan and crop to re-frame.
    The final DVD has a strange habit that the first few frames from each of these adjusted segments were larger, and then the picture would jump in to match the pan crop settings I had used.
    Is this some type of GOP problem? has anyone seen this before?
    Chris
    Chris Callaghan replied 18 years, 6 months ago 2 Members · 2 Replies
  • Don Bloom
    March 20, 2008 at 2:41 pm
    did you set the KEY FRAME in the P/C window to the very beginning of the timeline? Sometimes I get too fast and it’s a few frames off the very first frame and causes a panning effect until it hits the key frame.
    Don
  • Chris Callaghan
    March 27, 2008 at 12:37 am
    Thanks for that hint, Yes, there is only one keyframe.
    It looks like the problem is related to the “Quantize to frames” setting.
    Once I had set that on, then problem resolved itself.
    I suppose I should RTFM
    Chris
