Activity Forums Adobe After Effects Aspect ratio in 3D compositions
  • Aspect ratio in 3D compositions
    Posted by Daniel Paniagua on February 25, 2010 at 2:18 am
    Open AE CS4 and created a 3d composition to generate a cube of solid rectangular (360×288 px) mode PAL1 / DV (720×576), The problem is that I can not match Las 6 sides to a cube is formed tightly closed,Although all sides have the same size. Delivery of a solid of 360×288 then doubled,Change their attachment points at z = 288 for the first z =- 288 for the second.With that in the separated 576px.Then duplicate one of them (side 3) and broken at y = 90 °.It double again and so broken in y =- 90 º.The problem is that when generating the other side (rotated at x = 90 º and -90 º) do not match their size and the cube side is left with some different size, I understand that this issue is aspect ratio.Is there a solution or failure of the program is?
    Joey Foreman replied 16 years, 6 months ago 2 Members · 1 Reply
  • Joey Foreman
    February 25, 2010 at 5:44 am
    Could you post a screen grap of your entire AE UI, showing all layers?
    Have you tried changing the layers’ Transfer Modes to Alpha Add?
    Are you using Collapse Transformations?
