Activity Forums Apple Final Cut Pro Legacy aspect ratio for animation integrated into dv anamorphic
  • aspect ratio for animation integrated into dv anamorphic
    Posted by Elizabeth Bak on August 2, 2008 at 7:43 pm
    I’m working on a sequence with 23.98fps footage that was shot in miniDV with a Panasonic DVX100b, anamorphic. I’m incorporating some animation sequences into this cut and am a little unsure of what aspect ratio/resolution to advise the animator to work in (animation will be done in after effects). Final output will be for film festival screenings and possible broadcast on TV.
    My sequence/clip settings are 23.98fps, 16×9, 720×480.
    1. Is it advisable to have the animation done in a higher resolution (like HD) in case I want to upres at the end of the project (this is a film) or will that just complicate integrating the animation into the sequence of minidv footage?
    2. If I just wanted the animation to match the footage in my sequence at its current resolution and aspect ratio, what are the optimal specs?
    Sorry if this seems like a basic question, any and all suggestions would be greatly appreciated.
    Elizabeth Bak replied 18 years, 1 month ago 2 Members · 2 Replies
  • David Roth weiss
    August 2, 2008 at 9:27 pm
    [Elizabeth Bak] “2. If I just wanted the animation to match the footage in my sequence at its current resolution and aspect ratio, what are the optimal specs?”
    I believe that would be 853×480 pixels for NTSC or 1024×480 pixels for PAL.
    [Elizabeth Bak] “1. Is it advisable to have the animation done in a higher resolution (like HD) in case I want to upres at the end of the project (this is a film) or will that just complicate integrating the animation into the sequence of minidv footage?”
    It wouldn’t hurt to have the animation done at 1920×1080 to be future-proofed.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Elizabeth Bak
    August 2, 2008 at 9:35 pm
    Thanks so much for the guidance, you just saved me many headaches!
