Activity › Forums › Apple Final Cut Pro Legacy › Aspect Ratio Conversions
  • Aspect Ratio Conversions
    Posted by Adam Taylor on June 29, 2006 at 11:02 am
    I have been asked to convert some material from a 4:3 aspect ratio to 19:9 – its been delivered as .VOB files on a dvd.
    I have been using Mpeg Streamclip to extract the material, but i’m unsure which is the best way to alter the aspect ratio, whilst maintaining as high a quality as possible, before re-burning the material back to a dvd again.
    I am working in PAL, so my thinking was to extract using a pal DVCPRO50 codec, set to 16:9, deinterlacing, highest quality setting.
    Is there a better way to achieve the aspect ratio conversion?
    “silly keeps you sane”
    Mark Maness replied 20 years, 3 months ago 2 Members · 1 Reply
  • Mark Maness
    June 29, 2006 at 2:36 pm
    Sounds pretty good so far, but I would suggest extracting to Uncompressed from a DVD. It will look much better in the long run.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
