Activity Forums Adobe After Effects aspect ratio confusion
  • aspect ratio confusion
    Posted by Roger Burton on February 28, 2006 at 11:58 am
    I’m almost embarrassed to ask this question but I have a D1/PAL (1.07) comp into which I drag my DV footage and it fits fine … when i bring in a Photoshop still that I’ve created at 720 x 576 square pixels it comes into the comp too small on the x axis … anyone point me in the right direction please … I know I can hit (cntrl, alt F on the PC to make it fit but there must be something I’m doing wrong) … thanks for your time … Roger
    Michiel replied 20 years, 7 months ago 3 Members · 2 Replies
  • Unai Guerra
    February 28, 2006 at 4:51 pm
    It is probably a pixel aspect ratio problem. When you create a still in Photoshop, after clicking in File > New you can find a listbox with different presets. Select Pal D1/DV. 720×576 (with guides) and you
  • Michiel
    March 1, 2006 at 2:36 pm
    switching the interpretation of your imported photoshop file to D1 non-square pixel aspect should fix the problem. If you wanna work with square pixels, you should use a size of 768×576, not 720×576
