Activity Forums VEGAS Pro Aspect ratio changes from original import
  • Aspect ratio changes from original import
    Posted by J.p. Bowmann on December 27, 2008 at 8:49 pm
    I am using Sony Vegas Movie Studio 8.0 to import Windows Media Video files to ‘tune’ the color balance and the contrast, etc. I cannot get the Sony Vegas output file to match the original imported file in size and aspect ratio … the out put ‘flattens’ the image somewhat. Any suggestions would be appreciated.
    Also, are there any schools on Vegas Movie Studio? I think I need to go to one! Many thanks in advance for any suggestions.
    Alex Hemp replied 17 years, 8 months ago 3 Members · 2 Replies
  • Jeremy Rasnic
    December 29, 2008 at 4:26 pm
    Can you give us the imported files spec’s as well as the spec’s once it is on the timeline and then tell us how you are rendering the file?
    If I am not mistaken, you are limited in what you can do with the consumer version of Vegas when it comes to customizing output settings. I could be wrong on this as I do not own the consumer version. Maybe I need to obtain a copy so I can better answer these sorts of questions 🙂
    Give us some more information and I am pretty sure we can help you out.
    j razz
  • Alex Hemp
    January 6, 2009 at 12:39 pm
    Hello,
    I’ve very new to Vegas and had the same problem with JPG’s being stretched to fill the screen. The only way I could fix it was to right click each image in the media store area and then select properties.
    The properties menu then had an “aspect” drop down option that I changed to 1:1. It worked a treat, but I do have to carry out this operation on every single image I import. 8o(
    This may sort the issue for video files, but I have not tried.
    Best Regards, Alex.
