Activity Forums Apple Final Cut Pro Legacy aspect ratio
  • Posted by Chris Monberg on May 8, 2010 at 9:03 pm
    1st time here and new to video…Plese help,
    I shot with the hpx 170 @ 720p 60p too the firestore fs 100….. imported into final cut pro. After editing my project im having problems exporting and keep the 1280×720 that my files show in finder….FCP says they are 960×720 ????? why did they change on import? was it something I had wrong in my FC import settings? and can I change the file size on my project back to 1280×720? So I can export the size i shot in? I’ve tried lotts of different exports from quicktime to compressor and every time i export it squeezes my files with black bars on top and bottom????? my final output will be dvd and a lrg quicktime file……. my project is an ice skating show….
    Any help would be greatly appreciated?
    chris
    Chris Monberg replied 16 years, 4 months ago 3 Members · 10 Replies
  • 10 Replies
  • John Pale
    May 8, 2010 at 9:12 pm
    The format you shot in actually shoots @ 960. The pixels stretch to 1280 for display. This is normal for r an anamorphic format.
  • Chris Monberg
    May 8, 2010 at 9:18 pm
    does that mean im stuck with a streatched image with black bars on top and bottom? no way to export my project to view it full HD frame?
    thanks so much
    Chris
  • John Pale
    May 9, 2010 at 1:11 am
    If you use the right settings there will be no black bars, but since you have not told us exactly what you did, there is very little anyone can do to help you.
    Based on the dimensions, it sounds like your camera shot in the DVCPRO-HD (1080i) format. You should be using the Easy Setup for that in FCP.
  • Chris Monberg
    May 9, 2010 at 1:59 am
    hmmmm… sorry i thought i had all the details of how i shot it and what i did in FC on my first post. What other info would you need to tell me what i need to do?
    sorry….
    Chris
  • Andrew Kimery
    May 9, 2010 at 5:26 pm
    What are your exact sequence settings and what is the specific, step by step process you’ve used to export the footage so far?
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Chris Monberg
    May 10, 2010 at 5:23 am
    Thank you!
    sequence settings
    720×480 aspect ratio 3:2
    pixel aspect ratio ntsc-ccir 601/dv 720×480
    field dominance lower even
    editing time base 29.97
    quicktime vidoe settings
    compressor dv/dvcpro-NTCS
    quality 100%
    audio
    rate 48 khz
    depth 16-bit
    config channel group
    was this an import problem?
    can i go back to my timeline and get my settings back to the original 1280×720?
    or will i hv to re import and start my project over?
    Chris
  • John Pale
    May 10, 2010 at 7:33 pm
    Your sequence settings are completely wrong. That is the setup for DV/DVCPRO NTSC. You want DVCPRO HD 1080
    Use the Easy Setup for DVCPRO HD 720p60.
    Use the EASY SETUPS!
  • Chris Monberg
    May 10, 2010 at 7:42 pm
    ok great
    so do i want DVCPRO HD 1080 or DVCPRO HD 720p60
    Thanks Chris
  • John Pale
    May 10, 2010 at 8:19 pm
    I think i wrote the wrong format earlier.
    Your dimensions are 960 x 270 (which displays as 1280 x 720)
    This is 720p DVCPRO-HD.
  • Chris Monberg
    May 10, 2010 at 8:55 pm
    great ive figured out to set it to those settings and recut the project…..
    the problem started when my friend clicked no instead of yes when FC asked if the project settings should match the sorce when we dropped it on the timeline…!!!! oh well live and learn…
    Thanks for your help…
    Chris
