Activity Forums Broadcasting Aspect Ratio 16:9
  • Aspect Ratio 16:9
    Posted by Xtothed on January 6, 2006 at 12:58 pm
    Hi All,
    Hope this is the right place for this question – and I dont come across as too stupid!!
    In the past I have been asked to create a short advert in PAL 16:9. We filmed and edited in 16:9 – DSR450 & FCP & AE Pro. It looked totally fine in the edit and when I dumped it to Beta SP – UVW1800 – it seemed ok.
    This Sp was then transfered to Digi – the format needed to broadcast the advert – which was performed by another company – so I never got to see the Digi version. This Digi was then sent to the broadcastor and when I saw the advert on TV, the whole thing was larger than it should have been – with the text at the very edge of the screen/safe areas – even though in the edit the text was miles inside. I am not sure why this happened.
    To confirm, when editing in FCP, the footage should looked stretched vertically on a 4:3 monitor, until I press the aspect button – then the bars should come in and create the right aspect ratio. Similarly, when I dump to SP, the image as 16:9 should appear strecthed also. And then the broadcasting company’s output should sort the ratio to look ok on screen?!
    I will also post this in the FCP forum – and I hope I have given you enough info.
    Hope you can help.
    Sincerely
    Xavier
    Tony replied 20 years, 8 months ago 4 Members · 3 Replies
  • Jon Zanone
    January 6, 2006 at 2:25 pm
    The UVW can’t handle 16:9. How did you check the SP master?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Martin Baker
    January 6, 2006 at 9:57 pm
    There is no reason whatsoever why you can’t record anamorphic onto Beta SP. Sure it’s not as good as digi but neither format were originally designed for 16:9 – anamorphic video is essentially a hack.
    This problem is almost certainly an error on behalf of the broadcaster. It sounds like at some point in the chain the source was thought to be 4:3 rather than 16:9 anamorphic and as a result the image has been zoomed in. Time to start asking some questions…!
    Martin
    Digital Heaven, London UK
    ________________________________________
    NEW! MovieLogger – QuickTime logging made simple
  • Tony
    January 13, 2006 at 1:49 am
    It’s quite obvious what occured here.
    1) Somewhere in the chain of distribution the anamorphic material had a centercut extraction done which in effect cut off the text which had been composed for the 16×9 aspect ratio.
    Who is to blame here well sorry to say but it all started either before or during post production.
    First of all if the deliverables were to be both 16×9 and 4×3 (which a majority of shows must comply with 4×3 delivery) then it was the responsibility of the production company or editorial facility to create text within the 4×3 title safe area (center cut) to avoid cutting off the text and/or create two separate versions of the show. The first 16×9 and the second 4×3 which means two separate text passes to compose for the different aspect ratios.
    Another easier option would have been to create a letterbox version from the 16×9 anamorphic version but not all broadcasters might be willing to accept a letterbox program in lieu of a full screen 4×3 center cut version.
    So in a nutshell the lesson to be learned here is to always get the broadcast specs including aspect ratio deliverable in writing well ahead of shooting.
    The best method to avoid a mess in the end is to start at the end of the chain and work backward to fill in the gaps.
    No such thing as fix it in post (at least not cheaply or without major headaches).
    Tony Salgado
