Aspect ratio
Hi
I am new to Premiere and i am struggling with a problem. I am capturing Video from a Panasonic DVX100. When i open the capture window and capture a clip from the camera the footage looks fine (720×576 4:3), when i close the capture window and view the same clip in the main project area the clip appears to be in a wide screen format, stretched and distorted. When i check the properties of the clips and the sequence they appear to be fine.
Can any body help ?
Many thanks
