Activity › Forums › Adobe Premiere Pro › Aspact ratio problem…
  • Aspact ratio problem…
    Posted by Mark Liefhebber on December 26, 2009 at 2:03 pm
    I’m using Elements for my project. This probably is a simple problem, but i can’t seem to fix it.
    My original material has ben shot in 16:9 mode. When I got the captured material it was given with a ratio of 720/480 (3:2), so it looks cropped (horizontal). When I play it back with VLC player in widescreen mode it looks ok with black block on the top and bottem.
    In Elements I can only use presets, letting me choose from PAL (720/576) 4:3 or 16:9. When I export the material as wide screen, I get the same cropped view with the black blocks on the left and right side…
    Does anybody know how I can transform my material to it’s natural size in Elements?
    Ann Bens replied 16 years, 9 months ago 2 Members · 1 Reply
  • Ann Bens
    December 26, 2009 at 7:43 pm
    Select all the clips in the project bin and set interprete footage to widesceen.
