Activity Forums Boris FX Particle Illusion Artillery strike
  • Artillery strike
    Posted by Sam Rose on December 24, 2006 at 7:58 pm
    Hi
    I am wanting to make a scene where you see a hill in the distance and then you see an artillery strike. What effects in PI3 could I use to make this look as real as possible, I have been looking at barrage but are there any others?
    Also,do you know what forum I could ask to make a army like radio effect over my voice and where I could get an artillery strike in the distance sound effect?
    Sam Rose replied 19 years, 8 months ago 3 Members · 4 Replies
  • Sam Rose
    December 31, 2006 at 1:29 pm
    Anyone know?
  • Elvis Deane
    January 1, 2007 at 3:41 am
    Maybe a combination of Barrage and one of the Boom emitters in that same library? They work pretty good if you turn their Number off after a few frames, the last one is good for creating distant debris.
    There are two pretty perfect emitters to do this in the eclectic pro emitters set, grenade hit and something else similar.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Bill Hamell
    January 2, 2007 at 1:58 pm
    Using the Ground Hit and Flash Boom emitters from Pro Emitter Libraray PE_Ecletic_01 and the ring
    particial from Space Explosion 2.2 in the Deafult libraray I created the following effect.
    Bill
    Ground Explosion AVI
    Ground Explosion WMV
  • Sam Rose
    January 5, 2007 at 11:17 am
    Hi
    Thanks i will give it ago.
