Artifacts when placing png image on solid color
Posted by Josh Freeman on April 25, 2019 at 8:18 pmThis image explains it all:
I placed multiple words as PNG pictures with transparency on a solid color and both in preview and render artifacts (black thin lines) apear. How do I fix it?
I am on VEGAS 15Francois Pénzes replied 7 years, 5 months ago 3 Members · 4 Replies -
Graham Bernard
April 25, 2019 at 9:10 pm[Josh Freeman] “How do I fix it?”
Hi Josh. Yeah I’ve had that too. You going to need to go back and check the “artwork”. There’s an edge that you’re going to need to work-flat/feather to make sure that isn’t carried over. I can tell that that line is parallel to the bottom edge of your only angled “IDC” item. Or maybe a bit of Blur, restricted to that line.
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Graham Bernard
April 26, 2019 at 4:04 amYeah, careful preparation of artwork, meaning QA-ing of all the elements and layers, will save a lot of time, going forward. I know, I’ve ignored this and probably will again, but if I see something in VegasPro I’m almost certain nowadays to know what I’ve done wrong.
* Grazie
Francois Pénzes
April 26, 2019 at 3:45 pmHi Josh
Just to add to Graham’s response, lines will also show in your preview window when you are in any other mode than Best/Full. The lower the resolution, the more lines are visible. I get that sometimes also when masking. I can’t tell from your still what viewing mode you’re using. Could be just that.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
