Activity Forums Apple Final Cut Pro Legacy Artifacts when changing camera
  • Artifacts when changing camera
    Posted by Bendik Løvbrøtte on April 25, 2010 at 5:40 pm
    so i just finished exporting a theatre show from compressor, only problem is that there are tons of artifacts every time camera changes from an hdv camera to a dvcprohd camera. Anybody know of any fixes to this or is it just doomed to be like that?
    John Fishback
    replied 16 years, 4 months ago
    3 Members · 2 Replies
  • Rob Grauert
    April 25, 2010 at 5:58 pm
    What are the settings you’re exporting to? In my experience, compressing HDV has always led to artifacts, probably because it uses Long GOP compression.
    I’m not sure what others around here do, but when if I have HDV footage I convert it to ProRes first to get out of Long GOP compression.
    Since you’re done with your project, you probably don’t want to take the time to convert all your HDV, so I’d set your timeline compressor to ProRes or DVCPro HD since that’s an i-frame codec too. Then re-render your timeline, take it into compressor, then export.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • John Fishback
    April 25, 2010 at 6:53 pm
    If you didn’t use Frame Controls in Compressor, turn them on and choose the highest quality settings. This will take a while, but hopefully, improve the image.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
