Activity › Forums › Adobe Premiere Pro › Artifacts on upper edge of preview screen
  • Artifacts on upper edge of preview screen
    Posted by Juan Carreras on September 19, 2017 at 7:22 pm
    I have an annoying problem happening across many projects: my preview screen often displays a band of artifacts across the upper edge about 2-3 pixels wide when the preview plays (see attached). It seems to happen in the clips with video and not when I add a blank frame with titles for example. Sometimes it disapears if I resize slightly the frame size but it re-appears when I render the video previews. Fortunately, it doesn’t affect the final output but it’s nevertheless annoying .
    I’m using PPCC v7.22
    Any suggestions ? – Thanks
    11701_artifacts.mp4.zip
    Eric Merklein replied 9 years ago 4 Members · 4 Replies
  • Jerry Wise
    September 20, 2017 at 7:31 pm
    you can get that if you speed up or slow down footage. i usually just up-size it a bit.
  • Juan Carreras
    September 20, 2017 at 7:40 pm
    None of the clips are changed in speed, they are actually image sequences.
    Sometimes I’ve resized them up a bit as you suggested but since the artifacts don’t appear in the final output, I don’t bother anymore but I was hoping that there was a proper solution without having to resize. For what I gather, it’s a fairly common bug that has not been fixed.
  • Ann Bens
    September 21, 2017 at 10:52 am
    Might want to update to 11.1.2.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
  • Eric Merklein
    September 21, 2017 at 2:25 pm
    Hello Ann.
    Is version 11.1.2 available? I was in Cloud yesterday and didn’t see any updates for Pro?
    Thanks much.
    Eric
