Activity Forums Maxon Cinema 4D Articulating arm in 2 Directions
  • Articulating arm in 2 Directions
    Posted by Tony Barone on March 19, 2014 at 4:19 pm
    Adam, and Cactus Dan helped me out a while back with a similar model I was working on.
    I have this articulating arm, however in this model I now have two. They move along with this object that sits atop a stage that can up up/down, left/right and in/out.
    It is the In/Out motion I am having problems with.
    When the object moves on its X-Axis, the arm pulls apart. Is there a way to fix this?
    I’ve attached a file containing the model so far with its various motions.
    If you take a look at the arms, it should be somewhat clear how I’m trying to get them to “bend” realistically in this motion.
    7252_articulatingarms.c4d.zip
    Any help on this would be greatly appreciated!
    Tony
    Tony Barone replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
