Activity › Forums › Adobe After Effects › arrows, arrows, arrows,
  • arrows, arrows, arrows,
    Posted by Qeffects on August 26, 2005 at 6:21 pm
    How can I move several arrows along a spline at once with the ability to increase the count as well as increase and decrease their speed.
    Q
    Qeffects replied 21 years, 1 month ago 2 Members · 2 Replies
  • Filip Vandueren
    August 28, 2005 at 12:31 am
    Perhaps by using text on a spline with arrows from a dingbat font.
    You can animate the First-Margin parameter to move them across the spline.
    If you use an extra opacity animator, you can set the range to define howmany arrow-characters are visible.
  • Qeffects
    August 29, 2005 at 3:17 pm
    Thanks for the tip I will give this a try. Is there any way to do the exact same thing and substitute either a vector or bitmap instead of the text? I did find a few good arrows to use in WingDings font, so maybe that will work.
    Thanks again,
    Q
