Activity Forums Maxon Cinema 4D array point
  • array point
    Posted by Jason Boos on July 12, 2010 at 2:49 pm
    I created a spline on the XY plane. Afterwards, I applied the Array nurb to try and get the object to rotate around the Z axis. What’s happening is that the object is rotating around the Y AXIS!!!
    How can I prevent this from happening?
    Thanks in advance!!!
    Brian Jones replied 16 years, 2 months ago 2 Members · 4 Replies
  • Brian Jones
    July 12, 2010 at 3:27 pm
    the Array Object copies the original object with the Z axis pointing outwards from the center of the array. I’m guessing from your description you want your spline to be made on the YZ plane instead.
  • Jason Boos
    July 12, 2010 at 3:35 pm
    i guesss you can say that.
  • Jason Boos
    July 13, 2010 at 5:13 pm
    so how exactly can i change the plane?
  • Brian Jones
    July 13, 2010 at 5:45 pm
    if it’s a built-in parametric spline (like “Circle”) just change it in the Attribute Manager. If it is a spline you made by hand, or made editable or imported you have to rotate the splines axis with the Object Axis tool. 90° around the Y-axis probably.
