Activity › Forums › DVD Authoring › Argggh! DVDSP or the internal Pioneer burner is killing me!!!
  • Argggh! DVDSP or the internal Pioneer burner is killing me!!!
    Posted by Dorit Grunberger on May 10, 2007 at 6:21 am
    I seem to be able to toast .imgs OK, but to actually burn a DVD from SVDSP is impossible. This is the error I’m getting now:
    Start formatting
    Formatting as Standard DVD
    Simulation mode is off
    Lossless linking is on
    Number of layers is 1
    Doing side 1 of 1
    Playable in region 1,2,3,4,5,6,8
    Disc size is 12 cm
    Disc has no copyright material
    Writing ISO 9660 directories
    Writing UDF 1.02 structures
    Writing files
    The recording device reported the hardware error: Internal target failure. (0x44, 0x00.)
    It’s suggesting the problem is with the burner. Anyone seen this before?
    Rich Rubasch replied 19 years, 4 months ago 2 Members · 1 Reply
  • Rich Rubasch
    May 16, 2007 at 11:52 pm
    I think you are always better off doing an Advanced Burn and build the disc to your hard drive then burn with toast….you don’t have to burn an IMG file, but the actual VideoTS and AudioTS files in Toast. Using this workflow you will be able to easily make more copies if you need them.
    One thing to try, if you insist on burning out of DVDSP is to try trashing the compressor prefs and maybe the Finder Prefs.
    Rich Rubasch
    Tilt Media
