Activity Forums Adobe After Effects Area type in After effects
  • Area type in After effects
    Posted by Veggie on September 10, 2006 at 1:41 am
    I am stuck on how to get text to fill a custom mask shape like a normal paragraph, without distorting the type (like the area type tool in illustrator). In a recent post the using the path text effect was suggested, but I can only seem to get the type to run around the mask and not inside it. I’m sure it’s absurdly simple – well it should be! Any suggestions?
    Cheers.
    Steve Roberts replied 19 years, 8 months ago 3 Members · 4 Replies
  • Sam Moulton
    September 10, 2006 at 4:33 am
    Use the type tool. click and drag a type area just as you to in illustrator, then the text will wrap according to the rules you set in the paragraph palette.
  • Veggie
    September 10, 2006 at 5:25 am
    I mean using a custom shape (ie a mask or something) but having the type fill the shape rather than normal box shape.
  • Veggie
    September 12, 2006 at 9:48 am
    Yeah, but I want it to be editable text in after effects so I can animate using the text animation settings. Can you do this?
  • Steve Roberts
    September 12, 2006 at 1:19 pm
    No, sorry. You’d have to use separate lines of text (separate layers) that match the layout you want.
