Activity › Forums › Maxon Cinema 4D › Area Light with Shape
  • Area Light with Shape
    Posted by Justin Dutle on July 5, 2011 at 6:59 am
    I am fairly new to C4D. I have been trying to make an area light that emits light in a custom shape. I make the shape editable and put the area light as a child of the shape. And then under the light details mark the shape as object/spline and then drag the shape into the object line. I have seen several tutorials on this and followed them closely. I noticed that the built in shapes like square, disc, rectangle, etc. also do not work. No matter what shape is chosen the light remains the same. Do I have some setting wrong or is there something else I am missing. Thanks.
    Justin Dutle replied 15 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 5, 2011 at 3:13 pm
    try checking off Show in Render in the Details tab of the light. That should show you the shapes (and orientations) of the lights the settings give you
  • Justin Dutle
    July 6, 2011 at 4:22 am
    Thanks for the respons. The gouraurd shading was throwing me off, it doesn’t change according the the designated shape. You only see it when its rendered.
