Activity › Forums › DaVinci Resolve › Are used LUTs embedded in project when “LUT” check-box is included on project export?
  • Are used LUTs embedded in project when “LUT” check-box is included on project export?
    Posted by Nat Jencks on August 5, 2014 at 8:06 pm
    Hi, when exporting a project the user is given an option to include LUTs via a checkbox.
    Does this mean that if you send another user a project which has had this checkbox checked that any used LUTs will be embedded in the project file, and the user doesn’t need copy the LUT to the /Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT folder?
    -Nat
    Nat Jencks replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
