Activity › Forums › Adobe Encore DVD › Are Transitions with Alpha Channels allowed?
Posted by Eric Jones on January 4, 2008 at 7:42 pmGood Afternoon Forum,
There are a few things that I would like to try with Encore, I am making some motion menus in AE, and I was wondering, if I made a transition with an alpha channel could I get it to overlap two menus?
Eric Jones replied 18 years, 8 months ago 2 Members · 4 Replies -
Joe Bowden
January 4, 2008 at 10:06 pmYou have to create your transition material entirely in AE or Premiere, so whatever they support should carry over in Encore.
Eric Jones
January 8, 2008 at 6:30 amThaks Joe for your response, but I’m not sure I understand would I create the enitre project in Preimere or AE then Import in Encore?
I started building an Encore project from finished clips, and also made a transition as an avi file – is this not going to work?
thanks,
eric -
Joe Bowden
January 8, 2008 at 3:44 pmNo, not the project – the transition material (i.e., the video that contains a frame grab of the menu, followed by a transition to a clip or another menu, etc) – that transition clip must be made in AE or Premiere.
Eric Jones
January 8, 2008 at 4:02 pmThanks Joe,
For a quick response.
Yes I understand now, what you’ve explained I have done, however my menu is a motion menu…
so I would need that transition to crossover two different clips; alpha channel in use on both clips to make a transition happen as one clips ends (menu still in motion as transition occurs).That is my dilema, but from your explanation of a using frame grab, it seems as though my wish will not (at this time) be a possibility and I might have to use a work around.
