Activity Forums Adobe After Effects Are these specifications correct??
  • Are these specifications correct??
    Posted by David Jones on June 26, 2019 at 8:59 am
    Hi, I’ve put together a movie using After Effects and Final Cut pro. The specifications have to be as here shown:
    I exported the video out and played it on Quicktime and these are the specifications I saw for my video:
    Are my specifications correct? The file is so large that I can’t send it to anyone even when compressing it.
    Thank you!
    David Jones replied 7 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    June 26, 2019 at 2:53 pm
    You should double-check the audio specs; some systems cannot handle 24-bit audio.
    Everything else looks good. ProRes 422 HQ does require a significant amount of space.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • David Jones
    June 26, 2019 at 5:02 pm
    Thank you, Walter! Much appreciated.
