Are these 2D animation scenarios possible in FCP Motion 4?
Dear FCP experts,
(1) Are the following 2D animation scenarios possible in FCP Motion 4?
(2) If so, what keywords or product features should I be reading about in the ~1500 page User Guide?Here is a static image of the basic animation I want to make: https://picasaweb.google.com/markhooker/Animation001#5549583455862819890
Basic animation:
- The rectangles would start in the positions shown
- The path they take is shown in the thick black arrowed lines
- Each rectangle descends the vertical path it is on
- When each rectangle reaches the end of it’s vertical, it flies diagonally to the top of the next vertical path to the right
- Continue until each rectangle has moved through the end of the last vertical element of the path, when it just disappears.
Adjust Path; varying heights; update animation:
- Would then like to adjust the heights of the various verticals and simply have the animation update automatically.
- Would also like to adjust the equidistant spacing and have the animation update automatically.
Final Animation:
- Would like to have the heights of the verticals changing (moving up and down like on an equalizer display) and have animation adjust
(3) If it cannot be done in Motion 4, what application can do it?
(4) Please offer any other council you care to.The features I think I am looking for are: ability to define a “parametric” or “feature-based” “animation paths”. With such paths, animations made with respect to such paths would automatically update when the paths themselves were changed… saving immense amounts of time.
