Activity Forums Adobe Premiere Pro Are there are *HDV* footage stabilizing plugins anywhere?
  • Are there are *HDV* footage stabilizing plugins anywhere?
    Posted by Dave Graton on November 3, 2005 at 8:53 am
    I’m using HDV footage so I’m not interested in the DV stabilizer plugins.
    Using a stabilizer plugin on HDV and *then* down-converting to DVD would seem (to me) to be a no quality loss scenario.
    Can anyone help me out here? Maybe something that’s under development?
    -Dave Graton
    Tim Kolb replied 20 years, 9 months ago 3 Members · 6 Replies
  • Tim Kolb
    November 3, 2005 at 3:27 pm
    What stabilizer plug in is only for DV?
    As far as I know Steady Move could care less what you launch it on…it just handles pixels. The same would go for AE’s motion stabilizer.
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Don Huckleberry
    November 3, 2005 at 9:06 pm
    I have used the steadymove 2d3 (bundled w/premiere) with 720 p footage and it worked quite well. I was working in a DV rez project with the HDV imported into it.
    don
  • Dave Graton
    November 5, 2005 at 6:07 am
    Hi Don, Steadymove plugin is bundled with Premiere!!??
    Where can I find it?
    Also, you mentioned working with HDV footage in a DV project? Is it possible to use an HDV-based project with Steadymove?
    Thanks for the info,
  • Tim Kolb
    November 5, 2005 at 2:21 pm
    [Dave_Graton]
    Also, you mentioned working with HDV footage in a DV project? Is it possible to use an HDV-based project with Steadymove?”
    As I believe I mentioned…none of the effects in your effects directory are “DV only”…so why would a stabilizer be? Just as the Color Corrector will work on any project you have in Premiere DV, SD, HD, HDV…320×240 custom frame size…whatever, so will any other effect you have installed…like Steady Move.
    Haul out your PPro install disk, the Steady Move plugin is on it. You’ll have an option to install various things including the application…and the Steady Move plug in.
    TimK,
    Creative Cow Host,
  • Don Huckleberry
    November 7, 2005 at 6:36 am
    Dave,
    Hope you found it, I think it’s on the little installer when you autostart the disc. Or just look for a folder 2d3 or steadymove on your install CD.
    TimK – maybe he is just assuming it’s a trial that’s limited. I am pretty sure that the there are some free plugins (the cycore I think, with Mr. Mercury and particle playground) that come with AE that are limited to DV rez.
    Don
  • Tim Kolb
    November 8, 2005 at 9:11 pm
    [Don Huckleberry] “TimK – maybe he is just assuming it’s a trial that’s limited. I am pretty sure that the there are some free plugins (the cycore I think, with Mr. Mercury and particle playground) that come with AE that are limited to DV rez.”
    I guess I’ll buy that… But as far as I know, Steady Move isn’t limited in this way.
    TimK,
    Creative Cow Host,
