Activity › Forums › Event Videographers › Are the heads in my camera dirty, or is it just busted? Know any places in Los Angeles to clean video heads on a videocamera?
  • Are the heads in my camera dirty, or is it just busted? Know any places in Los Angeles to clean video heads on a videocamera?
    Posted by Clint Nitkiewicz hernandez on April 18, 2006 at 2:44 pm
    If you guys know any local places in Los Angeles where I can do this for a good deal, let me know, thanks.
    I own a sony vx1000, 3ccd chip videocamera.
    But also, for some reason, when I try to digitize the video from my camera, into final cut pro, the firewire output simply does not work. Final cut does not read it, I know its not the settings in final cut, as I used different cameras and it works fine,
    and the last video I shot came out very clumpy, digital boxes in the video, ugly, blah,
    so im assuming its the heads that need cleaning, and i know its not good to use your camera to digitize, but have no other choice for now,
    Thanks a lot,
    Clint Nitkiewicz Hern
    Tony replied 20 years, 5 months ago 3 Members · 2 Replies
  • Doug Graham
    April 18, 2006 at 7:06 pm
    The blockiness is most likely a small head clog. Run a cleaning tape for 10 seconds max and re-try.
    The failure to communicate may be another issue…could be a broken Firewire port on the camera.
    Regards,
    Doug Graham
  • Tony
    May 1, 2006 at 8:40 pm
    Less is more when running the head cleaning cassette.
    4 second maximum. Any more is bad for the heads in the long run due to excessive wear and tear.
    Tony Salgado
