Activity › Forums › Panasonic Cameras › Are the analog outputs for the HVX200 switchable to RGB?
  • Ron Shook
    December 2, 2005 at 10:52 pm
    Jiri,
    [Jiri Vrozina] “not possible.”
    Oh, well. Do you know if it downconverts for monitoring?
    Ron
  • Accountclosedduetopolicyviolations
    December 3, 2005 at 5:35 am
    I am sure it will have cable like Z1 for that.
    jiri
  • Gary Taylor
    December 4, 2005 at 11:37 am
    That would be interesting. In most of the cameras I am familiar the DSP processes the image in the RGB 4:4:4 colorspace to maximize the detail available to the processor. Only then is the footage downsampled to 4:2:2. I still wouldn’t be surprised if this were more an issue of market segmentation vs it being a technical challenge.
    Certainly not saying the camera isn’t going to be great. It will be the picture that will tell and I am expecting big things from this little camera. This was important for me because there is a local rental shop with a CineAlta that doesn’t have HD-SDI out. I was hoping to refine this workflow with the HVX-200, and along the way it would have been great to occasionally maximize the quality available with this camera too.
    Gary
  • Graeme Nattress
    December 4, 2005 at 12:38 pm
    Because of the use of pixelshift, which increases luma by taking away chroma rez, there never is a 4:4:4 RGB signal.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Gerry Brooks
    December 5, 2005 at 11:28 pm
    To record a DV “backup” recording as well as to P2 would require 2 Codecs. So “no” is the answer.
    Gerry Brooks
    Customer Support and Training Manager, Rexel Australia Video Systems
  • Barry Green
    December 10, 2005 at 8:45 am
    [scenecutter] “Will the component outputs be able to input to BetaSP with downconversion on playback?”
    They certainly should, yes. You can configure the cam to output a 480i signal, even when shooting HD, and that component output works fine on monitors, so it should work fine as an input to a BetaSP deck.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available at https://www.dvxuser.com/articles/dvxbook/ and at Amazon (https://www.fiftv.com/db)
  • Barry Green
    December 10, 2005 at 9:18 am
    [Ron Shook] “Oh, well. Do you know if it downconverts for monitoring?”
    Yes it does. The s-video and composite video ports will provide a live downconvert, and you can configure the component outputs to either display native, cross-converted, or downconverted signals.
  • Barry Green
    December 10, 2005 at 9:19 am
    [Ron Shook] “I ask if it is possible while shooting PVCProHD and/or DVCPro50 to record to miniDV tape a downconverted DV25 backup?”
    Not possible. There’s a physical switch that reboots the camera into either tape mode, or P2 mode. When in P2 mode, the tape drive doesn’t even appear to exist to the camera. You can’t even eject the tape when in P2 mode! So no, no simultaneous recording possible.
  • Toke
    December 10, 2005 at 9:26 pm
    So, in p2 mode tape drive doesn’t exist, but in tape mode p2 do exist?
    Can you transfer material from tape to p2 when in tape mode?
  • Barry Green
    December 10, 2005 at 10:30 pm
    [toke lahti] “So, in p2 mode tape drive doesn’t exist, but in tape mode p2 do exist?
    Can you transfer material from tape to p2 when in tape mode?”
    No, it’s one or the other. You can’t transfer from tape to P2.
Page 2 of 2
