Activity Forums Media 100 are firewire 800 HD fast enought to digitize dv and dvcam in m100i?
  • are firewire 800 HD fast enought to digitize dv and dvcam in m100i?
    Posted by Macmauro on November 20, 2005 at 12:34 am
    Hi
    i use m100 8.2.2 and scsi uw2 10.000 rpm raid
    if i get an external hard disk Firewire 800
    digitize dvcam tapes is possibile at maximum resolution?
    I can’t understand this, cause I image the FW800 connection is fast
    but the disk records at 7200 rpm.
    What is the standard for HD used in broadcast production?
    And what about the thermal calibration?
    When i bought my first video editing system, one said was necessary to use AV hard diskes
    at 10.000 rpm or more and without thermal calibration. Now? For firewire HD?
    thanks
    Maurizio
    Ted Joyce replied 20 years, 9 months ago 3 Members · 3 Replies
  • Ernie Santella
    November 20, 2005 at 2:48 pm
    For what it’s worth, when my SCSI raid went south, I bought a FW400 drive with a fast Oxford 911 interface for a quick interm fix. It worked perfect up to 300KB on M100 8.2.2 (I don’t have uncompressed).
    So, FW800 should be no problem also.
    Other inexpensive drive systems to consider are SATA raids. Much faster than FW800 and cheap. Here’s an interesting article.
    https://www.hdforindies.com/2004/12/review-of-firmtek-seritek-1se2-and
  • Macmauro
    November 20, 2005 at 3:19 pm
    nice article, thanks a lot; i have now more clear mind about
    M.
  • Ted Joyce
    November 20, 2005 at 7:26 pm
    I’ve been using FW 800 drives for a year with uncompressed on M100 w/ no problems. If you have a lot of audio tracks put them on an other drive
