Activity › Forums › Apple Final Cut Pro Legacy › Are 4 gigs of ram better than 4.5?
  • Are 4 gigs of ram better than 4.5?
    Posted by Stu Siegal on January 6, 2006 at 3:16 am
    Got the minimum of 512 with my G5, then bought 4 1 gig chips, seem to remember reading somewhere on here that I might be better off taking out the 512K when installing the 4 gigs, as the system will run better with chips of all the same size. Is this correct?
    Stu
    David Fortin replied 20 years, 9 months ago 4 Members · 3 Replies
  • Jack Fox
    January 6, 2006 at 4:30 am
    Haven’t heard that, actually I’ve heard reports that there is no penalty for different size pairs.
    jmf
  • Jeff Carpenter
    January 6, 2006 at 5:44 am
    I think what you’ve heard is that mixing different brands of RAM raises the chance that something won’t go quite right and you’ll get freezes and other errors.
    But if you’ve bought your new RAM from someplace that promises to pick out the most compatible RAM for your Mac then they’re probably selling something that works well with what Apple uses.
    I added 4 GB to my original 512 and I’ve had no problems. I say go for it, but just keep it in mind that if you have lots of unexplained problems you should take the 512 out and see if that fixes it. I doubt you’ll have any problems, though. Just something to keep in mind in case there is a problem later.
  • David Fortin
    January 6, 2006 at 2:53 pm
    Same here.
    I’ve been running with 4.5 RAM since I got my G5 [Nov. 2004], also with no problems.
    Was interested in the responses to your question though. I was hoping I haven’t been “slowing” my G5 down with the extra 512.
    David
    Dual 2.5 G5 {OS 10.3.7}
    4.5 GB RAM
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    FCP Production SuiteHD 4.5
    Media Cleaner Pro 6
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
