Activity › Forums › Square Box CatDV › Archive to FTP
  • Archive to FTP
    Posted by Nathan Mcalpine on July 6, 2012 at 1:04 pm
    Is there a way to archive through CatDV via FTP? Our archive requires us to FTP our footage back and forth and currently CatDV is not a part of this process. Any suggestions?
    ~ Nate
    Matthew Stamos replied 14 years, 2 months ago 3 Members · 2 Replies
  • Bryson Jones
    July 6, 2012 at 4:04 pm
    Worker Node can send files via ftp, although on larger files with versions before Worker v5, you can have trouble with time-outs so you might want to brake the transfers out to a separate script.
    Using CatDV you can copy files to any volume that will mount to the OS (there are utilities that will allow you to mount the ftp volume to your machine) but as has been mentioned here, it won’t preserve the folder structure of those copies.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Matthew Stamos
    July 10, 2012 at 3:51 pm
    When using the worker you can execute a curl command to deliver files to an ftp see here for more info
    https://forums.creativecow.net/thread/278/469#490
