Archive-Heavy Documentary Workflow in FCP7 — What do you all think?
Hello all!
We’re launching into a very archive heavy feature documentary, and just wanted to run the workflow we devised past you folks to see what insights you might be able to provide with your collective wisdom.
We’re cutting in ProRes LT 1080 23.98 in FCP 7. We made this workflow under the assumption that we want to avoid cutting subclips into our edit sequences, due to the horror stories that abound of onlining issues when cutting with subclips. We decided to log clips by marking them but then realized that text in markers are not searchable in the browser unless the masterclip is open (which is not feasible for a project of this size). Therefore, we came up with this workflow to still take advantage of the searchable features of subclips, both within the browser and within sequences:
Logging:
1. Add log note to each masterclip with general keyword for topic (same as the name of the bin, since bin names are not searchable)
2. Log masterclip with markers
3. Create a folder labeled “[bin name] For Searching ONLY” and drag markers from masterclip into this folder (this allows us to search markers in Browser)
4. Create stringouts by subject using subclips and label them “[subject] For Searching ONLY”Cutting:
1. Only cut from masterclips, using markers and in and out points
2. Do not cut with subclips
3. Use keyword search function in timeline to find Subclip X
4. Match frame Subclip X to Subclip Parent Clip:
a. Position playhead over the subclip in the sequence.
b. Hit “View > Match Frame > Subclip Parent Clip” or assign shortcut.
5. Insert Clip X from viewer into edit sequence.What do you all think of this? Any potential issues you can foresee? Is there a more streamlined way you all have done for a project like this that might be more streamlined? What works for you?
Thank you all so much for your help!
-Dan
