Activity › Forums › Adobe After Effects › Architectural drawing effect?
  • Architectural drawing effect?
    Posted by Antony Buonomo on June 28, 2005 at 10:00 am
    Hi
    Does anyone have an approach for this-?
    The director has footage of a city skyscraper in situ, there is minimal camera movement. The idea is to change the building from glass and steel to a a kind of hand-drawn/architectural/blueprint look.
    Any ideas gratefully received.
    Antony
    Nigel Kennedy replied 21 years, 2 months ago 3 Members · 2 Replies
  • Anonymous
    June 28, 2005 at 3:21 pm
    possibly you can use 3d stroke. It would allow you to create outlines in 3d space
  • Nigel Kennedy
    July 9, 2005 at 11:38 pm
    is the building an image or a 3d model?
    if it’s a 2d image, u’ll probably need to use the edge filter in photoshop to kind of create the lines…if it’s 3d model, there should be some kind of toon/lines plugin (illustrate in 3dmax) to make the blueprint lines of the building.
    then u can bring into aftereffects to merge it with your real building image.
