Activity › Forums › Apple Final Cut Pro Legacy › ARC tip – works well and gives great image quality
  • ARC tip – works well and gives great image quality
    Posted by Adam Taylor on October 9, 2006 at 12:51 am
    just thought this might be useful to anyone having to do aspect ratio conversions from 4:3 to 16:9.
    In FCP I input the 4:3 footage at 10bit uncompressed, then convert it to 16:9 by using the scale and distort settings in the viewer. Increase the scale to 135 and the distort to 33.33. This gives a reasonable 16:9 output from the 4:3 material.
    Next, export the entire sequence (i work on commercials so this is not a problem for me) as a quicktime movie using the same settings as sequence. Open this file in Shake, in the globals, set the format to 16:9 non square, add a fileout node directly to the filein and use a quicktime movie with 10 bit uncompressed codec. Render and reimport into FCP.
    The new material will have a much sharper, cleaner image than that given by FCP alone. I guess it just has better algorithms – but i have have tried it on several commercials and it always looks amazing. If you need to arc, give it a try.
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Adam Taylor replied 19 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
