Activity Forums VEGAS Pro Arabic Titler for Vegas 6
  • Arabic Titler for Vegas 6
    Posted by Marwan Silbak on October 19, 2007 at 11:30 pm
    I have Vegas 6 and runs in Windows XP with Arabic Language Enabled. I tried to type ‎Arabic text and Vegas will write them correct from right to left. The text direction ‎should be from right to left. I contacted Vegas and they do not support Arabic Text ‎Direction right to left. Do you know about any other tilter software will allow Arabic and ‎work with Vegas 6? I have been using Pinnacle 9 for years and allow Arabic Titling. Do ‎you know if I can use Pinnacle tilter software or not?‎
    Adam Rose esq. replied 18 years, 5 months ago 3 Members · 3 Replies
  • Adam Rose esq.
    October 20, 2007 at 8:08 am
    I had the same problem with using Farsi in Vegas 5 & 7, so used another program to get Vegas to display it correctly. Was painful, since create text in (eg) notepad, copy into this other application, then copy it out of there and paste into the Vegas titler.
    NOW it’s no longer an issue, since vegas 8 supports unicode text, so can create it directly in vegas.
    I suggest you download the trial version – the time saved / ease of use should pay for the upgrade(USD135) immediately
  • Marwan Silbak
    March 23, 2008 at 7:56 pm
    I bought Vegas Pro 8 and wodnering how you were able to get the Arabic to work? Can you help.
  • Adam Rose esq.
    March 24, 2008 at 12:37 am
    my friends are using the Protitler to do all the farsi stuff, and it works fine
    can’t remember if they be pasting it into PT or typing straight in – think it’s the latter.
