Activity › Forums › Apple Final Cut Pro › Applying Transitions – choose the place to drop them like in FCP7?
Posted by Sascha Engel on October 4, 2013 at 7:39 amHi,
I have a Q considering the Transitions in X: In 7, I could choose, when dragging a clip, if it was supposed to be added to the left, right or centre of the edit point between the two clips. Is there a way to do the same in X?
And: In PPro and AVID I can adjust the sides of the Transition unsymmetrically – can I do the same in X? If yes, how?Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikangSascha Engel replied 12 years, 12 months ago 5 Members · 13 Replies -
John Fishback
October 5, 2013 at 3:06 amCheckout this thread. Alex has made free dissolve transitions that start or end at the edit point.
https://forums.creativecow.net/readpost/344/1095John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Sascha Engel
October 5, 2013 at 8:29 amYes, that seems indeed one of the big faux pas of X.
It’s still weird to me, that on one side, they made such genius new features into this App, and forgot about the most basic ones a pro app needs – like this feature, or OMF, or many other things.
I really hope, they close that gap soon, since I do thing X is in many ways pretty genius.
I have a project right now, where the client brought mixed frame rates – PAL & NTSC – and I threw it all on one PAL TL and it work fantastic in real time.Sascha Engel
http://www.youtube.com/taikang -
Sascha Engel
October 5, 2013 at 8:32 amThanx John, sounds great.
I will check out, first thing in the morning, when I come to the studio (here the week starts on Sunday;-)Hope it will do what I need.
Unfortunately, all transitions should behave like that in X.
That it’s only applicable to the centre and only possible to change right and left symmetrical is a shame.Sascha Engel
Sascha Engel
October 5, 2013 at 11:02 amI’m taking it all back, I just found out how to do it to all clips in X – thanx Mr. Larry Jordan!
Sascha Engel
Sascha Engel
October 5, 2013 at 4:06 pmI hope, I describe it the right way, out of my head. I don’t have the app in front of me right now:
When you drop the transition in the TL on the edit points, if you drag on either right or left side, you lengthen or shorten the transition. If you grab either end of the transition in the upper grey part, you do a Ripple edit of the transition to either side, and when you grab and move the symbol in the upper middle of the Transition, you do a roll edit. With those function you can do exactly what I was looking for.Greetings,
Sascha Engel
James Ewart
October 5, 2013 at 4:11 pmOK Thanks.
I have been using the Precision Editor for this which makes it easier to see.
It would still be useful to be able to select one of the three “start on” end on” etc though.
Sascha Engel
October 5, 2013 at 4:18 pmI totally agree, but for now it’s an ok work around.
Still hope, that all those things still will be fixed in future version.Sascha Engel
Charlie Austin
October 5, 2013 at 5:00 pmFWIW, that’s not the case with all transitions. Specifically with “Dip to Color” , you can adjust the mid-point with a slider in the inspector, effectively letting you choose to start at the beginning, end, or anywhere in between the 2 clips. Way better than the “old” way. Sadly, that adjustment doesn’t exist in the Dissolve. Send feedback! 🙂
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~
