Activity › Forums › Maxon Cinema 4D › Applying textures to different polygons
  • Brian Jones
    October 19, 2018 at 7:35 pm
    depends on what you want, you can select polygons and make a selection tag and assign that to a material so the material only show on those polygons and you can make all the polys in an object with the Variation shader
