Activity Forums Adobe Audition Applying Noise Reduction To An Entire Sequence From PP CC???????
  • Applying Noise Reduction To An Entire Sequence From PP CC???????
    Posted by Joel Dalls on August 10, 2013 at 5:14 pm
    Hi:
    I have a sequence of multiple video clips with their audio tracks all on the same audio channel in Premiere Pro CC. I need to apply noise reduction in Audion.
    When I select all the clips and export the sequence, I see the sequence in Audion. However, when I switch over to “Waveform” in Audition in order to apply the NR, I only see a short portion of the audio — not the entire sequence.
    Can someone tell me (or point me to) the solution to seeing the whole sequence in the waveform section of premiere?
    Thanks!!!!!
    Joel Dalls replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
