Activity › Forums › Adobe Photoshop › Applying filters to high-res images has little effect
  • Applying filters to high-res images has little effect
    Posted by Ryan Moyer on April 18, 2012 at 2:52 pm
    When applying filters such as accented edges, ink outline, etc to a medium sized image (1024×768 or 1280×853) produce some pretty cool results.
    However, when applying those same filters to larger images like files with a 5184×3456 resolution, the filters have little to no effect. I’m guessing this is because there are so many more pixels that altering each pixel has a less noticeable effect.
    You can see an example here with the accented edges filter run over a smaller version of a picture I took, and then a larger one (that was then downsized to make it viewable):
    https://www.vcize.com/images/accented-edges-1280×853.jpg
    https://www.vcize.com/images/accented-edges-5184×3486.jpg
    The 1280×853 one looks pretty cool. On the larger 5184×3456 version the filter had almost no noticeable effect.
    The problem is that I want the cool looking version like is seen in the 1280×853 version, but at a high enough resolution to print on a large canvas that is, say, 40′ x 40′ or so. Is it possible to get the bigger image to look like the smaller one without losing the resolution required to print it on a canvas that large? I’ve been trying to figure this out for weeks now…
    Ryan Moyer replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
