Activity › Forums › VEGAS Pro › Applying filter to Video Output FX but not subtitles
  • Applying filter to Video Output FX but not subtitles
    Posted by Grzegorz Kwiatkowski on September 2, 2013 at 9:41 am
    I want to apply a filter on whole project (all tracks) but excluding subtitles which are on the top track. How to do it?
    In Adobe Premiere there is an option of transparent adjustment layer which affects only tracks below. Can I do it in SV12?
    thanks
    Norman Black replied 13 years ago 7 Members · 30 Replies
  • 30 Replies
  • John Rofrano
    September 2, 2013 at 2:38 pm
    [Grzegorz Kwiatkowski] “I want to apply a filter on whole project (all tracks) but excluding subtitles which are on the top track. How to do it?”
    There is no way to do this easily. You would have to add the FX to each and every track except the subtitles track. Alternately, you could add it to the Master Video Bus, mute the subtitles track, render the video, then drop the video back into the project under the subtitles track, unmute the subtitles and render again without the FX on the maser bus.
    BTW, subtitles should not be burned into the video but that’s up to you.
    [Grzegorz Kwiatkowski] “In Adobe Premiere there is an option of transparent adjustment layer which affects only tracks below. Can I do it in SV12?”
    No, there is no such concept in Vegas Pro.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    September 2, 2013 at 2:57 pm
    I like John’s first solution, but why not use an embedded project instead of a rendered file?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    September 2, 2013 at 3:28 pm
    [Stephen Mann] “why not use an embedded project instead of a rendered file?”
    [slaps forehead with palm of hand] Of Course! Now why didn’t I think of that???
    (need more coffee)
    Yes, use a nested project. No rendering required 😀
    ~jr
  • Steve Rhoden
    September 2, 2013 at 4:11 pm
    As i’ve always said, Nesting is an incredible feature of Vegas!
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Grzegorz Kwiatkowski
    September 2, 2013 at 5:20 pm
    finally I found a way to do it. Actually there is adjustment layer option in SV12 and it works fine! Watch this:
    https://www.youtube.com/watch?v=JDD4fsE5oZY
  • Aleksey Tarasov
    September 2, 2013 at 5:44 pm
    Grzegorz – Wow, I did not know this trick! Great find!
  • Stephen Mann
    September 2, 2013 at 6:30 pm
    Thanks, ten years of using Vegas and I still learn something new every day.
    Steve Mann
    http://www.mmdv.com
  • Norman Black
    September 2, 2013 at 8:48 pm
    Yes, Very nice tip.
  • Steve Rhoden
    September 2, 2013 at 10:48 pm
    It can function almost like the Adjustment Layer in After Effects.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Rofrano
    September 3, 2013 at 1:19 am
    OMG! And to think that this has been there since Vegas Pro 10.0 and none of us knew about it? Is it a bug? because if it were a feature you’d think that Sony would be advertising that like crazy!!!
    Wow, That was a great find! THANKS!!!
    ~jr
Page 1 of 3
