Activity › Forums › Apple Final Cut Pro Legacy › Applying Filter on Time Line of FCP5
  • Applying Filter on Time Line of FCP5
    Posted by Stevan Pope on May 7, 2007 at 9:11 pm
    Help! I have applied the “Broadcast Safe” filter to several clips on the timeline, some give me the check mark in green indicating the clip is safe and within standards. Other white text on black background clips are reading or indicating the yellow ! warning. I click on Effects and select “Broadcast safe,” and then render it, but it has no effect. What am I doing wrong?
    Please advise,
    Thank you,
    Stevan
    Steven Lambion replied 19 years, 5 months ago 2 Members · 1 Reply
  • Steven Lambion
    May 8, 2007 at 2:48 am
    For Text there are two easy fixes.
    the first one is to go into the filter and change the amount of whiteness the filter is conserving or lowering.
    The Second and best for rendering is to remove the broadcast safe filter from the text and actually change the color to a darker one. You just need to move the slider a little down so it still looks white but it is low enough that it wont past the 100% white mark.
    Hope this Helps!!
    Video Specialist
    Apple Developer
    Owner of GranitWorks
