Activity Forums Adobe After Effects Expressions Applying expressions via a script – problems with variables
  • Applying expressions via a script – problems with variables
    Posted by Simon Björk on January 4, 2011 at 9:45 am
    Say I have the following script.
    var myComp = app.project.acitveItem;
    var myCamera = myComp.layer(1);
    var myLayer = myComp.layer(2);
    and I want to connect the rotation of my layer to the rotation of my camera. For that example,
    myLayer.rotation.expression = “thisComp.layer(“Camera 1″).transform.zRotation”;
    would work I guess. But what if I don’t know that the camera name is “Camera 1”? Is it possible to use the variable myCamera somehow? I mean, for example it would be easy if I could say: myLayer.rotation.expression = “myCamera.transform.zRotation”;. But that doesn’t work.
    So my question is if it’s possible to use variables set in scripting to your expressions?
    Dan Ebberts
    replied 15 years, 8 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    January 4, 2011 at 4:11 pm
    In your example, is myCamera a variable within your script that holds the name of a camera? If so, this should work:
    myLayer.rotation.expression = myCamera + “.transform.zRotation”;
    Dan
