Activity Forums Adobe Premiere Pro Applying effects to a region of a clip
  • Steven L. gotz
    May 9, 2005 at 11:51 pm
    Yes, and yes.
    You don’t work with the original. you use a new layer, or actually, a second instance of the same clip. You apply the effect to the entire second instance and then use a garbage matte to just show the area you wanted to modify. Garbage mattes can be keyframed.
    If the Premiere Pro 1.5 16-point Garbage Matte is not enough, then you have a lot more work to do and should be using After Effects, which is designed to deal with much more complicated masks.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Marcelo Lewin
    May 10, 2005 at 12:33 pm
