Activity Forums Adobe After Effects Applying Converted Audio Keyframes to only one axis
  • Applying Converted Audio Keyframes to only one axis
    Posted by Bryan on February 6, 2007 at 4:51 pm
    What’s the expression if you want converted audio keyframes to only apply to the x OR y axis (not both x and y, or z for that matter). When you pick whip to the channel slider from a position transformer of an object, it applies the expression to both axis’.
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp, temp]
    How would this be changed so it only effects the x or the y.
    Thanks.
    -B
    Mylenium replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mylenium
    February 6, 2007 at 5:22 pm
    [Bryan] “temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp, temp]”
    [position[0], temp]”
    or
    [temp, position[1]]”
    Mylenium
    [Pour Myl
