Activity Forums Adobe After Effects Expressions Applying Converted Audio Keyframes to only one axis
  • Applying Converted Audio Keyframes to only one axis
    Posted by Bryan on February 6, 2007 at 4:50 pm
    What’s the expression if you want converted audio keyframes to only apply to the x OR y axis (not both x and y, or z for that matter). When you pick whip to the channel slider from a position transformer of an object, it applies the expression to both axis’.
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp, temp]
    How would this be changed so it only effects the x or the y.
    Thanks.
    -B
    Dan Ebberts replied 19 years, 7 months ago 2 Members · 1 Reply
  • Dan Ebberts
    February 6, 2007 at 6:19 pm
    X only:
    [temp, value[1]]
    Y only:
    [value[0], temp]
    Dan
