Activity › Forums › Adobe Premiere Pro › Applying audio effects to master clip?
Posted by Aynsley Baldwin on March 23, 2017 at 7:00 pmHi folks,
Is there a way in Premiere to apply audio effects to a master clip, as opposed to individual instances in the timeline?
I’ve found information on how to do this with video effects, but no such luck yet for audio.
Cheers!
AynsleyJon Merrifield replied 8 years, 2 months ago 3 Members · 2 Replies -
Peter Garaway
March 23, 2017 at 7:14 pmSorry, this is currently not supported.
https://www.adobe.com/products/wishform.html
Best,
Peter Garaway
Adobe
Premiere Pro -
Jon Merrifield
June 27, 2018 at 12:14 amThat’s all true Dave. However, another thought would be sending to Audition and back (creates new audio clip in project) this could be a completely viable and useful option since audio effects to master audio clips is not supported. I was searching for the same thing as I often doing master clip color/effects to Slog ftg etc. My issue in finding this thread was similar with an audio piece, although often I send to Audition to capture and repair noise etc., I wanted to apply effects clip wide to a master clip to eliminate all the copy and pasting I might have to do for 50 some edits to an audio effected voice or sfx track. My first thought was to apply to the master clip just like I do with color often. Although I screw up often and work hard to not paint myself into corners, I am not sure how applying a simple audio effect to a master clip, say making a eq adjustment or applying a filter, may have potential for screwing up my audio big time. Now of course, not being done this exact road, I have no experience with issues or obstacles or Premiere inadequacies that may appear on this path. Thanks for letting me chime in. I ended up selecting the audio clip in the project window, right clicking and “Edit in Adobe Audition/clip” function. After applying the needed effects in Audition, I was rewarded with a new “extracted” clip to use as my source pre-effected.
Jon Merrifield
PELi VFX
