Activity Forums Maxon Cinema 4D applying animated textures
  • applying animated textures
    Posted by Michael Tannock on May 17, 2005 at 8:34 pm
    If anyone can help me find out what I’m doing wrong, I’d very much appreciate it. I’m having trouble creating animated textures.
    I know exactly what to do when creating an animated texture. but it only works when I use as a texture, simple animations that I created using cinema4d.
    when I try to use an animation which I have created, each frame painstakingly painted pixel by pixel, it dosn’t work.
    Brian Jones replied 21 years, 4 months ago 2 Members · 3 Replies
  • Brian Jones
    May 18, 2005 at 3:18 am
    More information please. What is the format the of the frames (or animation) of your handmade stuff?
  • Michael Tannock
    May 18, 2005 at 8:42 am
    The type of file is a gif.
    It’s location is C:Documents and SettingsMy Documents
    width 48 pixels
    height 48 pixels
    horizontal resolution 96 dpi
    vertical resolution 96 dpi
    bit depth 32
    frame count 6
    it may not sound very large, but it did take a lot of hard work.
    so I hope this information helps, thanks.
  • Brian Jones
    May 18, 2005 at 11:04 pm
    I think you will have to find a way to change your gif’s into Quicktime or avi’s. Quicktime pro can do that, I don’t know what else might on a pc.
