Activity Forums Adobe After Effects Applying an effect to a mask messes up the layers position??
  • Applying an effect to a mask messes up the layers position??
    Posted by Chris Mellor on February 10, 2022 at 2:24 pm
    The layers in this screen grab should be perfectly aligned, but when I add the Tritone to a mask it screws up the position. As if the effect turns on some cropping of the layer and offsets the transform stuff. It didn’t do this when I set up the project… this is somehow new. Purged the cache, nothing changed.
    https://imgur.com/a/52aGKHe
    View post on imgur.com
    Andy Kiernan replied 4 years, 7 months ago 2 Members · 1 Reply
  • Andy Kiernan
    February 11, 2022 at 1:49 pm
    does it do it with CC glass turned off? if that fixes it, maybe the glass effect is still referencing the mask somehow… if that doesn’t fix it (and yer I know that’s not a fix anyway) use a matted adj layer maybe?
