Activity Forums Apple Final Cut Pro Legacy Applying a transition to multiple tracks?
  • Applying a transition to multiple tracks?
    Posted by James Keenan on June 10, 2010 at 1:05 pm
    Hi Guys,
    I have a clip on my timeline of a presenter speaking on a white background. Directly underneath that on another track I have a colour solid that im using to cover up some rough edges on the presenter clip using cropping.
    I have a separate intro clip that im trying to cross dissolve into the above clips but when I try and apply it it will only let me apply it to the presenter clip and its sound track, not the colour solid.
    Is there a way I can highlight the presenter and solid clip and apply the exact same cross dissolve?
    Im using FCE4 so I can nest the clips which I think might be a useful technique of doing this.
    Sorry if this is a really easy problem to solve, Im new to all of this.
    Many thanks in advance.
    John Fishback
    replied 16 years, 3 months ago
    2 Members · 1 Reply
  • John Fishback
    June 11, 2010 at 6:53 pm
    Nesting should work. Try it and see.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
