Activity › Forums › Adobe After Effects › Applying a Matter After Effects
  • Applying a Matter After Effects
    Posted by Robertp on November 8, 2006 at 6:27 pm
    I have used a preset of a starfield followed by a radial blur so that the points of light become streaks. What I want to do is to set up a mask to gradually blend off the outer edges of the streaks so they don’t touch the edges of the screen. When I apply a mask with feathering, it masks out the points Before the radial blurring takes place. How do I apply the mask After the radial blurring takes place?
    Robertp replied 19 years, 10 months ago 2 Members · 2 Replies
  • Michael Duff
    November 8, 2006 at 9:24 pm
    Pre-Comp the layers you want masked (select them and hit ctrl+shift+c) then apply the mask to the precomp….
    lots of effects need to be pre-comped, even if there is only one layer, before you can apply additional effects or transformations….
  • Robertp
    November 8, 2006 at 11:31 pm
    Thanks, the answer was so obvious that I missed it!
