Activity Forums Adobe After Effects Expressions Apply wiggle to multiple layers with different values
  • Apply wiggle to multiple layers with different values
    Posted by Phil Bauch on April 12, 2015 at 3:45 pm
    I have a comp with several layers. At every layer I’d like to wiggle position, scale and rotation, but independently (so using a null layer is not the right idea…).
    Is there anyway to create a “global expression”, that applies e.g. to an array of al the layers? Or do I have top copy/paste the expression to every layer (not very handy, cause its a lot of layers…)
    Thanks in advance for any ideas. Cheers, Phil
    posterizeTime(10); wiggle(10,10)
    Dan Ebberts
    replied 11 years, 5 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    April 12, 2015 at 4:24 pm
    Each layer will need its own expression. But, all you have to do is select the property with the expression on one layer, Edit > Copy Expression Only, select all the other layers, Edit > Paste.
    Dan
